Brief Description: Back up alternator installation...
I started the day by installing the tachometer drive cap as I will have the tachometer indication on the Advanced Flight Systems display come from the P-mags. Then I installed the back up alternator on the accessory drive pad that is normally used for a vacuum pump but I will have an all electric system for instrumentation.
Tachometer drive cap installed
Back up alternator installed on the vacuum pump pad
